you need to have pin code from your car and vcds cable
car battery to be more than 13v
your pin code
go to engine
login
enter your pin code do it
go back to adaptitaion 10
read 050 in channel number
read pin code
save done and go back and wait 2min with ignition off
after start the car enjoy!
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
ivanrojo (7th November, 2018), Stelaras26 (14th November, 2018)
Ok, so just necesary pin code from car not from fuel pump car donor great thanks!
And pin code could be read from engine ecu am i right?
that car has not flash, it has two plc32, i tried to do it. reading pin with vag k can and trying to do the process with vagcom but i have problem with too many error comunication, i think my vagcom is almost dead.
Are you sure, that this 2002 AUDI is with this pump (immo related)?
Are you sure, that the new (second hand) pump is good?
ivan1 (9th March, 2019)
Hii, yes second pump was unount from a running car with same engine.
I think problem is with my vagcom when i try to coding interface stop working.
Maybe the interface is fine, but when you try to coding, the ECU stops responding because of wrong condition, or missing functionality...
without learn immo car must start and stop. This is no problem in immo.....
FILE SERVICE
they only swap fuel pump, not possible with vagcom enter on coding, car doesn´t start and stop just not start
Try with launch.
ivanrojo (13th November, 2018)
Hi car has not flash, it is old ecu, 2 PLC32 i can read them and upload files if it is possible to do it on plcs. thanks to all.
xxxxxxxxxxxx
Hi.
If you have a regular vag kkl or vag k commander 1.4 / 2.5 you can turn off the immo in the engine control unit. (EDC15) If this does not give anything then you should check the ECU errors. Setting the timing and the pump itself. In addition, vent the pump well. Check also whether the engine fires on auto-sharpening, for example PLACK for cleaning, polishing upholstery.
https://www.youtube.com/watch?v=56-9YAPp3lY
