no bmd needed ... obd read is enough ... best software is winols .... the idea behind bdm is totally different
Hi All
Just after a little info, to remove my DPF and EGR would I need to do a full BDM flash or can it be done in the car? If it can be done in the car what is the best software to use?
Is the idea behind the BDM flash to modify checksums similar to the full 512 flash for the ms43 ecu in E39's etc?
Much appreciated.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
Ah ok cheers, I thought WinOls was a binary editor that didn't have flash capability?
Do you speak software to edit file or read ecu?
Read/write the Ecu I meant
WHAT YOU NEED OF A KESS V2, CMD, MAGPROG FOR EXAMPLE
Andy61088 (20th November, 2018)
I bought Kess and read the ECU partially and fully, apparently (both files 2048kB). Could anyone remove the DPF and EGR? Do I need to modify any checksums etc befor flashing back onto the car?
much appreciated
Your kess will calculate the checksum and correct it before it starts to write...
When I helped you press Thanks and Reputation...
Andy61088 (24th November, 2018)
Your file dpf egr off.
Thank you very much!
