its work ?
its work ?
Hi, why won't it let me download the file, shows me I'm not registered.
Czy będzie działał z opcom1.7
This Opcom SW version is for HQ Clon interfaces. Works with interfaces purchased from SKLAD 66 (one-time activation required).
I have a Chinese clone converted to HQ clone but it does not work with this version.
After activation, my HQ clone runs with Opcom version 17xxxxxEN.
If you have a real PIC 18F458, it is better to use the software made by FANTOMEL.
(Opcom SW : 11ADV 15PRO, 16ADV , 17PRO, 18PRO and 20PRO EN)
https://www.digital-kaos.co.uk/forum...=1#post4058794
please send me pass thanks
hey all,cani have the pw please? also somebodycan help? i had op com v1.99, i flash with opcom FW1.60 how to or where to get FW for 1.99 back or FW to work with opcom 2014 again?
thank you and merry xmas to all, enjoy the festive season and be safe
makka079If your opcom originally had FW 1.99 and you updated it to FW 1.60, you have irreversibly damaged it. .
You can fix it by changing the fake PIC to a real PIC 18F458 and programming it with an external programmer.
However, it is best to buy a second Opcom with a real PIC 18F458.
On Aliexpress, all Opcoms with FW 1.99 have a fake PIC.
Opcoms with a true programmable PIC most often have FW 1.95.
makka079 (18th December, 2023)
Hi Mario ,thanks for the reply! the one i updated still passes the test in china clone opcom 08, not yet tried it on the car! i have also purchased another opcom, after reading it with ocflash it shows the firmware as 1.95, i dont want to mess with this unit, just pointing to the correct version of software to use with it if you could help?
thanks again for your help
This Opcom (1.99) will not connect to any controller when connected to the car.
The second cable with FW 1.95 should be of good quality and have a real PIC. (the last real FW is 1.67) FW 1.95 is a Chinese invention.
What Opcom SW are you using now with this cable?
Yes, on OS WIN 10 64 bit SW 12xxxxx and all Opcom 15, 16, 17, 18 and 20 made by Fantomel work very slowly.
It's the same on OS WIN 8.1.
It is better to use OS WIN 7 32 bit (I don't remember what it is like on OS WIN 7 64 bit).
It is safest for you to use Vauxcom 12xxxx.
However, if you want to take a risk, use SW made by Fantomel (Opcom 15, 16, 17, 18, and 20 Pro)
(my post #171)
Good luck.
Hi Mario, sorry for the delay in responding!!! do you know of or can point me in a good copy of the software and driver i need for the v1.95? the other one will be going in the bin! currentlt running win 10 but am trying to go to win 7
thanks for your help! merry xmas too you and your family my friend
Hi.
You can install all (FANTOMEL) versions from 11ADV to 20PRO on one laptop. They do not interfere with each other. Try them all and then stick with the one that suits you best. (e.g. 16ADV and 20PRO)
The drivers are (the same) in every main folder with SW Opcom ---"DRIVER". They can't be newer.
I think that the Chinese FW 1.95 does not require changing to the real 1.67. But you can do it using OCFlash.
-15/16 PRO FW 1.64
-16ADV FW 1.65
-17PRO FW 1.66
-18/20 PRO FW 1.67
Merry Christmas.
