Results 1 to 11 of 11
    May 2008
    Default Lost firmware / ck3 faulty
    Was trying to update my 1.5 firnware to 1.6 on liteon drive , musing junglefalsher , made a mistake , lost firmware , also green light no longer lights up when tochong 707 point , so it does not dump no more , think board is faulty , is their any other way I can flash drive , junglefalsher still sees drive , I managed to try the dos method , but it fails . any ideas please ?
    DK Veteran Time2Play's Avatar
    Apr 2009
    you need to read the key iff you have lost it mate only way best thing is to lend someone elses ck3 or u will have to buy anothe ror pay for recovery
    May 2008
    how long is warranty from kanection , i bought it in feb 09 ? thanks
    cunny's Avatar
    Jan 2009
    The Shoutbox
    so jungleflasher still recognises the drive?
    May 2008
    hi yes it does but cant get any futher as when i put probe on 707 there is no green light now , so it doesnt dump ect come up with error
    cunny's Avatar
    Jan 2009
    The Shoutbox
    You say its flashed as 1.5 ix?
    NO need for spear, with correct port selected, click get key from ixtreme on the dvd key tab.
    Page 85 of the new jungleflasher guide
    Apr 2009
    heh cunnys right i forgot once a lite on has been flashed once it relinquishes all protection just load the drive up and hit get key mate should read it for u
    May 2008
    H not sure if i can as i think i erased 1.5
    sent off ck3 board ,
    if jungleflash is seeing drive , are you saying i can use iextreme to still get key ? which version please thanks and what exactly do i need to connect to drive please , thanks
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Quote Originally Posted by rks View Post
    If JF is still seing the drive then you couldnt have erased it. Use the Dummy from Ixtreme tab in jungleflasher to read the drive and it should pull the info you need.
    Then reflash the drive with the latest firmware.
    Patience is a virtue.
    Dec 2009
    If you have erased the drive and you dont have the key then you have a brick mate.
  11. #11
    Apr 2009
    iff u have not got the ck3 board then u will have to power of fthe 360 make sure metal is touching metal tho as the pc is alot more powerful than the 360 and can fry it
