Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: bsi JC problem
  1. #16
    Oct 2018
    Europe
    Great explanation, Just a question on this, so the problem is when fvdi is been used to read pin code from Johnson control for key programming/learning? so by NOT trying to read pin using fvdi there wouldn't be a problem in the first place? Therefore why don't people get pin from other source or device first? then this problem would not be happening, Am i correct on this?
  2. #17
    Oct 2018
    Europe
    I meant to quote this, sorry for last post
    Quote Originally Posted by garabounga View Post
    Maybe its better explaine here:
    HI. AFTER HAVING THIS PROBLEM SEVERAL TIMES WITH BOTH GENUINE AVDI & CLONE FVDI I HAVE FOUND THE FOLLOWING;
    ON SOME JC BSI UNITS FVDI/AVDI CORRUPTS THE FLASH WHEN IT READS IT. IT WRITES A NEW FLASH TO ENABLE IT TO READ THE EEPROM, THEN WHEN IT TRIES TO PUT ORIGINAL FLASH BACK IT FAILS CHECKSUM BECAUSE IT IS CORRUPT & THEN LEAVES BSI DEAD IN BOOTMODE.
    I don't believe adding power by jumpleads etc. makes any difference whatsoever as reported by others on here. There are just some versions of software that it always seems to corrupt. Even if you read the flash before reading pincode it will be corrupt.
    THE FLASH IT READS IS STORED IN MY DOCUMENTS FOLDER / ABRITES software for ID ******/psa. This will vary slightly depending which version of windows you are running but look in my documents search for psa or maybe view by date modified & it will be obvious.
    The problem is you need an undamaged flash at this point. There are some available on here & other forums. I have not been able to find a few anywhere. Do NOT write the flash or it will wipe the eeprom & need to be reconfigured.
    My solution, tested & working 100% on numerous vehicles;
    1. Find your flash id by opening bsi with fvdi & get 4 digit software signature. Then obtain a good file with this id.
    2. Go to the file location & replace the corrupt file with the good 1. Make this file write protected. It must have the exact same name as the original eg. JCI_BSI_7F0B.bin
    3. Perform the pin read again with fvdi & it will work correctly, give you the pincode then the car will come back to life. You can then program keys or whatever you wanted to do in the first place.
    4. As long as you keep the good file in its location & write protected fvdi will always work ok for any bsi with the same software signature.
  3. #18
    Mar 2015
    Yes that's correct To be honest with you IT took me quite some time to figuire out what the problem is and sinds that time i never used fvdi to Read pin i Just open bsi 5 minutes and Read pin in most cases dont even need to desolder eeprom i Read with original carprog.then i sure its gonne be alright
  4. The Following User Says Thank You to garabounga For This Useful Post:
    Brof (11th November, 2018)
  5. #19
    KriptoKey's Avatar
    Feb 2012
    Hello brothers ,
    I have made the connections in my table and I can now scan on bench BSI JC. To restore this BSI JC I need the flash "software signature 7FAD" can someone help me with this file to restore? The locksmith who was watching this car says he does not have the file backed by FVDI.
    I hope someone can help me with this 7FAD file.
    thanks for your help
  6. #20
    rafal's Avatar
    UK - PL
    Write message to doctore user.
    need help
    now my goal is to buy xp-005
    who will help?
  7. The Following 2 Users Say Thank You to rafal For This Useful Post:
    brend (12th November, 2018), doctore (12th November, 2018)
  8. #21
    doctore's Avatar
    Nov 2015
    Colorado Denver
    I do not have this flash
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  9. The Following User Says Thank You to doctore For This Useful Post:
    rafal (12th November, 2018)
  10. #22
    Mar 2015
    Try this one i found in DK
  11. The Following User Says Thank You to garabounga For This Useful Post:
    rudoni (21st July, 2022)
  12. #23
    Oct 2015
    bonsoir garabounga
    c'est possile d'avoir le mot de pass
    merci
  13. #24
    Aug 2018
    Russian Federation
    Default Software signature: BA90
    Hi guys! killed my bsi can't find
    I would appreciate your help.
    CheckSumm Error
    Hi guys! killed my bsi can't find S
  14. #25
    Dec 2020
    Default Recherche flash bsi jc 04ev
    Salut les amis je recherche dump flash
    Pour bsi johnson controls
    ev04
    Signature logiciel f3.e4
    Svp bsi planter avec fvdi
    Merci de m'aider
  15. #26
    Aug 2021
    ROMANIA
    Quote Originally Posted by garabounga;[URL="tel:3418778"
    3418778[/URL]]Maybe its better explaine here:
    Thank you my brother, you saved me today,i was reading my friend bsi to find pin code in bsi and car died, I followed your guide and worked stait ahead, God bless you, thank you very much
  16. The Following User Says Thank You to abelf10 For This Useful Post:
    markuuuu (13th June, 2024)
  17. #27
    Apr 2020
    garabounga ,Password plz....
  18. #28
    Jun 2024
    A lot of useful information here u guys are great I hope you can help me after Reading here and follow step after step I got to know my JC bsi have 41.c5 Signature and no one have it on the internet or posted it here because I do have dead BSI after trying to read my pin and bought another one and same happened I am trying withe the used bsi I got from the same model if some one can help me to get this flash and try to start my car
