Results 1 to 12 of 12
    bmw320d's Avatar
    Default Help with ecu Audi EDC17CP20 XRom
    Hi guys I need if possible a full backup tricore with ktag of Audi A4 8k 120ps Edc17CP20 Xrom 0281016572 03L906019AL
    Thanks in advance
    carmageddon's Avatar
    Italy
    Quote Originally Posted by bmw320d View Post
    Thanks in advance
    i have this...backup with fgtech, is the same of ktag
  3. The Following User Says Thank You to carmageddon For This Useful Post:
    bmw320d (9th November, 2018)
    bmw320d's Avatar
    Thanks Carmageddon, tomorrow try it
    bmw320d's Avatar
    Hi Carmageddon I have tried with ktag to rescue ecu with restore but I have error file not compatible, I would be able with odis online to reprogramm the ecu?
    Italy
    you can not use "restore" function, you must to write each single component : e2p, int flash and ext flash
    bmw320d's Avatar
    not work, if I use a single component, ktag write operation not possible
    Italy
    why say operation not possible?
    which version you are using?
    bmw320d's Avatar
    I use ktag 2.23, not ID of ecu
  10. #9
    Italy
    possible bug in software 2.23....try 2.25 or previous version as 2.08/2.11 with fw 6.xxx (obviously with appropriate hw)
  11. #10
    Summa's Avatar
    Nov 2018
    Restore the ECU with ODIS
  12. #11
    bmw320d's Avatar
    [possible bug in software 2.23....try 2.25 or previous version as 2.08/2.11 with fw 6.xxx (obviously with appropriate hw)]
    Hi, tried with 2.25 but same problem, not ID ecu not write with error Operation not possible
  13. #12
    bmw320d's Avatar
    [Restore the ECU with ODI]
    Hi I can restore ecu with odis? This ecu hasn't comunication can, not diagnosis
