hi good day - have nissan micra 2012 with K13 vin number - bcm have eeprom 93c66 with a pin code 8639 and we code the transponder with tango and the immo light is solid - when trying to read the bcm code with tester it fails - does anyone have another k13 bcm dump i can compare or check the attached dump or any advice on coding procedure - 7936 transponder
regards
