Thread: Checksum help
    Nov 2018
    england
    Default need help
    Greetings it is my first time using winols, I have edited the egr hysteresis map and removed the dtc and would like to confirm I haven't made any mistakes and my checksum is correct, everything is ok according to winols but as its my first time using I would rather someone with a bit more experience checked over the files for me, I have included both the original and modded files, thanks in advance.
    vw golf mk5 1.9 pd bkc
    03G 906 016 CB
    028 101 190 0
    EDC16u1
    Last edited by dannyanto9292; 11th November, 2018 at 10:32 AM. Reason: forgot to add ecu details
    ivanmihov's Avatar
    Nov 2016
    Europe
    your checksum is corrected OK,what tool did you use to read this ecu, it's better to let your tool do the checksum
  3. The Following User Says Thank You to ivanmihov For This Useful Post:
    dannyanto9292 (11th November, 2018)
    Nov 2018
    england
    I used mpps v13 to read the file from my ecu i am planning on flashing the modified file with the same tool
    ivanmihov's Avatar
    Nov 2016
    Europe
    you should not have any problems,just put you car on charger
    Nov 2018
    england
    Thanks for the reassurance, i dont have a battery charger but am intending on hooking my second car up with jump leads to keep battery voltage up, will this be acceptable?
    ivanmihov's Avatar
    Nov 2016
    Europe
    yes it's ok
