Results 1 to 5 of 5
    Nov 2009
    Default Fiat Seicento MC68HC11 dump
    Hello !
    I need dump for MC68hc11F1VFN4 ,because I lost my file and my ECU is dead ... IF is possible with I**O OFF ,if not I will use the I**O Killer . It is about IAW16FM.EC . FIAT 600 0.8CM ,year 1999-2000 .Thank you very much.
    You have all my respect for this forum and for all users and rulles.
    Jun 2009
    Try this one.
    Nov 2009
    Default Fiat seicento
    I hope it is working ... I will try and I will told you about this . Thank you anyway .I be back !!!
    Nov 2009
    ok I had desolder the MCu and I did not know how to program the circuit
    Nov 2009
    Default Fiat Seicento MC68HC11 dump trouble ?
    I have a question the file posted here ,if I use IM*O KILLER is modified by the programm ? IS that file IM*O OFF or not ? I used now IM*O TOOL and is the same problem it is modify 3 lines of code .WHY ?
