try this file.
Although, everything should have worked with OPCOM - HighSpeedBusProgramming
Hello Everybody!
I have transferred automatic gearbox (af40) to manual F40, and got DTC U2106-00 (no communication with TCM) and check engine light on. I Have disabled TCM and shift lever in all modules.
Maybe someone can disable this dtc in ECU, or maybe need to pull out and open ecu, then write new software?
CAR: 2008 Opel Vectra C 1.9cdti 110kw,
Ecu flash readed with MPPS v18
Thanks for your time!
try this file.
fedez (12th November, 2018)
Thanks! I will try tommorow.
so, wrote the file but no luck, same fault?
Change coding in ecu, if ecu not have possible edit coding use sps opel, flashing ecu to manual gearbox and you not have can dtc.
FILE SERVICE
You changed the Variant Configuration?
Did you change High/Mid/Low speed CAN config also?
If you not have SPS Opel, the Opel dealers have it for sure...
This procedure will cost about 50-100 euro, so what is the benefit to mess with software,
with this shity MPPS, wich reads only the half of the flash memory...?
I have oem xprog and can read/write everything what I need, but I have open ecu...if I have correct dump is no problem write it, but with new dump maybe new problems, Sport button, IDS...because at this day I don't understand OPEL software marks...for example my software nr. can be from 88kw engine, from manual too...so how to find correct one, maybe this is internal flash or eeprom correction needed...not external flash...
No need to find anything, just GlobalTIS and Pass-Thru cable.
1 day for download, instal and activate, about 11 gb of disk space... unlimited possibilities for change software on Opel cars till 2010.
mancioks (16th November, 2018)
Any Pass-Thru device is applicable.
There are and cheaper devices... But yes, better go to Local dealer...
J2534 compatible interfaces work with GlobalTIS. Mongoose GM, OpenPort or similar
fedez (16th November, 2018)
