You need the SD image to match the SD CID. Write the CID of any SD you have, I will try to help.
@mitsakos5800
works my created SD card correctly ?
Hi. I have a problem with Kess v2 5.017 SW 2.23 (green PCB). I can not run the software. Earlier I had such a problem but after moving the SD card everything worked. Now I can not run the software. A message appears. You know how to solve this problem ?
Mario6 (29th November, 2018)
gitko
Thank you for your reply. Unfortunately, I changed 3 usb cables and went on the same. Maybe the SD card is not working properly or bad soldering. Can someone put an SD image?
Yes, I'm sure. This is 5.017 with green PCB (SW 2.23). You can still buy one.
Clean sd contacts with isopropyl clean sdreader contacts and tighten them with slim tweezers.
If still not working trash the chinese sd and use good quality one with personal created sd image.
Mario6 (30th November, 2018)
I cleaned and bent the contacts. It did not do anything. I also changed the SD card and uploaded my image backup. Nothing has changed that. I will try to use the warranty from the seller. Thanks for showing interest.
