Results 1 to 3 of 3
Hybrid View
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Default VW Passat - DPF ON
    Hello, I have the VW Passat here with the problem of filling DPF at 30% after about 100km. The DPF OFF was made on the car. Now new DPF, 4x Injection, Differential Pressure. And somebody has corrected the map. Can someone please check the map.
    Thank you very much
    My English is little bit bad.
    Press Thanks and Reputation
    Nov 2018
    Germany
    best way, do ecu ID and post here maybe i have org file and i will do DPF
    regards
    Kocta's Avatar
    Mar 2017
    SW: 6576286583
    VIN nr.: WVWZZZ3CZ7P1xxxxx
    SW ver.:
    Spare:
    Engine: R4 2.0l PPD1.2
    HW Ver.:
    SW upg.: 03G997020N 4799
