Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Jun 2012
    89-BF these may be the pump flow values. I'm interested in being able to change them.I have EPS944, but the programming is very limited, and I cannot use one ecu programmed in another with a different reference.
    the ecu is bought virgin and the pump reference can only be programmed once.
    Do you only connect via k-line?
  2. #17
    Aug 2018
    East Pole
    Quote Originally Posted by Pepita View Post
    Hello khadang!
    I know some operations.
    The program is not for sale yet.
    Hello, Pepita. Regarding this... I have some psg5, but i cannot find out what cars and engine type are from. I only can connect them via kline and get the serial and some little version info. Do you have a list to identify them by car, engine, make etc?
    @Ricked: psg5 need programming if you want to use a ford ecm to a nissan or to opel etc... There are all the same hw, but the sw is that causing trouble. If you referred to Opel 1.7,2.0 psg5, or some bmw 2.0 ecms, yes, there will not be necessary to reprogram the immo part in it. Just to inform you, by example, there are some different versions, like: psg5 that works with x20dtl, but cannot work on y20dth type (just an arbitrary example), the ecu with the psg5 will not communicate correctly. So, just swapping them from a pump to another is not workking as you might think.
    The man here, @javiere asked for a reliable method to reproogram a psg5 i.o. to use it from a car makke to another...
  3. #18
    Hungary
    Hello volorucinski!
    I don't have a list.
    Some can be found in BOSCH ESI.
  4. #19
    Nov 2016
    Hello khadang!
    Pepita
    can you change the software in psg5 and clear the calibration field?
    I can change the application of the pump but not the software.
    do you read and change test data eps944? aapwdb.odb? priv
  5. #20
    Jun 2012
    Quote Originally Posted by krissr114 View Post
    Pepita
    that's what interests me, but I think it still can't be done
  6. #21
    ishvedoff's Avatar
    Belarus Gomel
    psg5_prog in Instagram
  7. #22
    Nov 2020
    Quote Originally Posted by javiere View Post
    hi
    know of a programmer who reads and writes one of these ecus of bombs vp30 vp44 ?
    0281010888 or 0281010480
    I'm not interested in repairing a transistor. just read and write the flash.
    but I do not know the protocol or the file size ..
    Can that programmer do that online?
  8. #23
    Nov 2020
    Valuable information. What about swapping PSG5 0281010888 from Audi A6 allroad (I think it's 2003) with A8 D2 (2000 facelift)? They both have the same engine, with the difference that A6 is 110kW engine and A8 is 132kW. PSGs are identical and interchangeable as stated in the table. I installed that one from A6 to A8 but no way it will work without decoding or whatever is needed there.
  9. #24
    Nov 2020
    PSG5 does not have flash memory.
    Pocessor 87C196 OTPROM. I do not know how to write.
    EEPROM 256 bytes.
    OTPROM means one time programmable ROM. So it speaks for itself pretty much.
  10. #25
    EEPROM Siemens SDA2526 reed and write i2c in circuit.
  11. The Following User Says Thank You to sany12 For This Useful Post:
    puki (12th November, 2022)
  12. #26
    Nov 2016
    Someone changed the use of psg5 or clears the calibration fields?
  13. #27
    Jun 2017
    subscribed. had a customer ask me about this today too. so far all information leads to pretty much nowhere apart from the pics of the software by Pepita on page 1 of this thread. is there any development on that??
    cheers
