Results 1 to 4 of 4
    Oct 2016
    Default Passat 3C Siemens to Bosch injectors conversion
    Hello! everyone!
    I own Passat 3C 2007 with Siemens PD injectors which 2 are shorted so the car have a no start condition.
    I purchased a (VW Touran) 2005 Bosch PD injectors and wiring loom, so i need a basic wiring conversion table for round connector right side on the cylinder head.
    Anyone had any luck with this conversion? I can easily flash the ECU to match the Bosch injection but have no idea how to convert the round plug pin out.
    Thank you in advance
    Feb 2010
    Poland
    Its impossible...
    cubica1's Avatar
    Feb 2012
    Serbia
    I have seen...possible. Injectors +ecu+immo off
    rgds,
    cuby
    hmm...I have just sniff on my base and find what I'm wrote---
    it was Passat 3C Passat_2.0_EDC16U34_03G906021LD_391532 and BKP engine...normally it is Passat Siemens SID ecu !!! But in this car was ECU + SW BOSCH system from Skoda 2.0 Bosch
    So it coused my headache, what's happen here!!!??? At the end, I have conclused that ECU is foultu anyway, so I have replaced the same and car was fine.
    BUT, to make change form Siemens injecotors to Bosch---is possible! For sure. I think also,....only one wire should be added, possible for driver pedals supply...not sure...
    dimitar's Avatar
    siemens ppd .......piezo injectors work at 250 volts level ....there is a inverter inside the ecu
    bosch edc..........solenoid injectors work at a level of 80 volts
    conversion possible with ecu , wiring , and sensors from another vehicle
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  5. The Following User Says Thank You to dimitar For This Useful Post:
    cubica1 (3rd December, 2018)
