Results 1 to 3 of 3
    Aug 2015
    Default Speed limiter problem with Renault Master 2011 2.3DCI 92kW EDC17C42
    I have problems with the speed limiter, i turned off the speed limiter to the 0x1967FE address.
    So the speed limiter has stopped working, but cruise control is also no longer working.
    I attached my files. Maybe someone can help for me ?
    Thanks in advance.
    dominik.m's Avatar
    Jun 2009
    POLAND
    Write ori file to ecu. You can change speed limit with diagnostic tool.
    Delphi clone can do it without problem.
    Aug 2015
    I know that solution with Clip and it easier than my solution, but i want to know where i made mistake for the future.
