use K-tag and write flash in boot on the table, of course only genuine have dcm3.7
FILE SERVICE
I did try to write with k tag but still dont start i think because off checksum i dident have good ori to compare in K-tag!! Do someone have good cs file to write with k tag ?
upload your file because I not understand how you write file if you not have orginal.
FILE SERVICE
This is the first read i did OBD
And the first read i did K-tag but it said checksum corrupt in k-tag
write this file by K-tag, If ecu have comunication and no start use frf file and flashing ecu than start.
FILE SERVICE
amtchip (21st November, 2018)
write by obd your file again and check
FILE SERVICE
I try with cmd flash obd but it wont write the file now. Also if i want to write Frf again it wont do it.
yes bacause immo is active, you must learn immo online or use k-tag and write your file in boot
FILE SERVICE
So the file i read first in cmd obd need to write in k tag MPC en then should start ?
yes, should be
FILE SERVICE
This week read same ecu with ktag well,and write
well ,car dont start erase immo data in ecu and
program original backup dont work compare files
ktag erase file in mpc.
must learn immo online,
