Results 1 to 7 of 7
    Nov 2018
    Default Activation Autocom Delphi 2014 Release 3
    Hello i need activation for Delphids-150e2014.R3 for car and trucks
    Serial number: 100251
    Hardware key: EGDFZJFAVQED
    Product name: DS150E (New VCI)
    Software version: 2.13.3
    Thanks Greg
    Dec 2014
    PL
    May 2019
    Ukrain. Zaporozhye
    thank you very much
    Mar 2011
    hello guys i have successfully installed v.2014.3 and drivers but when i check the hardware the program says that i have the the ds100e new vci and not the ds150e which i have.
    Everything works at first glance but why is that?
    Should i use different drivers?
    Thanks in advance
    Dec 2014
    PL
    Just use it. Do not worry about ds 100 or ds 150 if it works. I have the same.
    Aug 2019
    l have same problem are you fix it and how
    Dec 2014
    PL
    It is not a problem for me. The scanner works simply as DS 100 not as DS 150.
