    Jun 2016
    Default Renault Modus sim32 learning problem
    Original ecu water damage only eprom is ok. I bought used from scrapyard and use Renault tools.lt to virgin it and than program. Car start but after ignition off ecu change status from programmed to virgin and immo lamp stay so I bought another one. The same situation. After pograming car start once but after ignition off immo light.
    Adam
    Jul 2011
    it gives 2 solutions for sim 32 .
    Resolving eeprom does not help?
    Jun 2016
    Only eprom programing not working. I have to virgin ecu than program it by immotools. Car start one time only, after ignition off status ecu change to virgin. Ecus are 500kbps so like original.
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Quote Originally Posted by lexuspiotrkow View Post
    Adam
    RET makes ECU virgin, but you need to use CLIP: connect it to UCH, go to repair mode and send command SC017 "learn antitheft code to ECU". Clip can ask you to connect to Renault.net, i don't remember...
    Easier, use RET again, connect it to UCH (BCM) and send command 'LEARN ECM", that's all !
    Greetings,
    Jun 2016
    I do that. First RET to ecu - command virgin than go to uch and ecu learn, car start immo lamp go out but after ignition off than ON immo stay and use RET go to sim32, identfication/ ecu status - VIRGIN. 2 ecus the same
    Jun 2017
    French Jungle
    BCM => ECU learn => turn ignition off/ wait a minute => turn ignition on?
    If this doesn't work, try to disconnect battery after "Learn ECU".
    If it is the same, try the Renault way , if you have Renault Clip Tool.
