Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Dec 2009
    Default CIM problems Vectra C
    Hi, it all started when the cruise control turned off when I pressed the deceleration button. I bought an op-com and thought that the cim module needs resetting. so I did that, then the car would not start, found I needed to program the keys. Now the cruise control turns off whenever it wants an I get
    Source Address: CIM
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    U2103 - No Communication with CAN-Bus (High Speed)
    (00) - Not present
    Source Address: AIRBAG SDM
    U2139 - Invalid Data from CIM (Steering Column Module)
    (00) - Not present
    Source Address: PAS
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (00) - Not present
    and this one started to show about the time I reset the cim module, don't know if it's related:
    Source Address: IPC
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (7F) - Not present
    Can someone tell me if I need to reset/program other ecus after a cim reset with opcom, and if so how should I do this?
    Dec 2009
    please, I'm convinced someone here knows this stuff.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    Your car is <2005? Vectra C?
    ABS Light and ESP (if you have) have illuminate without reason?
    I think your problem is CIM, a very common problem on Vectra C/SIGNUM <2005.
    Your only hope is replace CIM. No repair kit avaible.
    I hope i'm wrong, but....
    PS: In attach you will find 2 pdf regarding your problem. I hope will help.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  4. The Following 2 Users Say Thank You to lupu_sandu For This Useful Post:
    akinorhan5 (1st February, 2019), Lexas (17th June, 2015)
    Dec 2009
    yes, it's august 2004... thanks for the info.
    There are some things I don't understand about the op-com. When it sais reset module, what does this reset do? does it erase the memory of the module and then you need to reprogram? because when I reset the cim it did erase the keys but I don't remember me reprogramming the cim module. the abs light and airbag does not light up. the only problem is with the cruise control.
  6. #5
    Newbie mark8's Avatar
    Dec 2009
    hi m8
    just had my cim replaced on my vectra c after doing the normal checks.
    check and clean the abs plug
    check the abs sensor
    and check all plugs from the cim to the control modules.
    but if all that is wrong is the cruise control. check the clutch return spring .
    best way to do this is that when the cruise control cut out hold the clutch pedal up and see if the cruise control work then.
    if it that then you will need to get the spring repair kit from vx only about a tenner
  7. #6
    Dec 2009
    Cairo
    The CIM is the Gateway for this vehicle, if you will reset the CIM it means
    1- this module is ready for replace
    2- this module is ready for reprogramming
    try to reprogram the module, and see if the communication codes of the Can-bus will vanish or not if these codes vanish and everything is ok check curise control programming on CIM, IPC, ECM
    if not then measure the signal ,and replace the defective ECU
  8. #7
    Jan 2010
    I'm getting the following errors using op-com:
    OP-COM - CAN Communication Window> 2005|Vectra-C / Signum|Vehicle|Vehicle DTC Information
    Read Info...
    Identifier: 0x0104
    Hardware number:24444336
    System name: EHPS GEN3 TRW
    Part Number:0
    Software version number: V20_
    System description: TRW 0300
    Alpha code:
    Code Index and version: 003 02
    Total number of fault codes: 2
    U2105 - CAN-Bus ECM Message Range/Performance
    (71) - Not present
    (00) - Not present
    Can anyone help?
  9. #8
    Jul 2009
    Problem is not SOFTWARE but Hardware ok?
    they tried to explain before.
    if you replace with new you have to code and learn keys + pin.
    if you replace with secondhand just copy 93C66
  10. #9
    Jan 2009
    Can a secondhand CIM be reprogrammed or do you have to get a new one???
  11. #10
    Oct 2008
    Greece
    Thumbs up
    Quote Originally Posted by spe03 View Post
    With one word: YES!!!!!
  12. The Following User Says Thank You to Patrian For This Useful Post:
    Stelaras26 (15th June, 2018)
  13. #11
    Jan 2010
    Before the new CIM is fitted, first note the following:
    Security Code
    V.I.N.
    Mechanical key number
    Variant encoding
    High Speed CAN configuration
    Mid Speed CAN configuration
    Low Speed CAN Configuration
    Run a full DTC scan and save the results
    Make sure that the V.I.N. in the other control devices consistent with the car
    Reset the old CIM
    Install the new CIM
    Configure the CAN-High, Low and Middle configurations
    Program V.I.N. and mechanical key number in the new CIM
    Program Immobiliser function, (choose CIM installed)
    Program the available transponder keys to the new CIM
    Reset the following devices:
    IPC
    REC
    BCM
    PDM
    DDM
    Switch the ignition off and wait at least 15 seconds
    Program the security code in the following steering devices:
    IPC
    REC
    BCM
    PDM
    DDM
    Configure the variant coding of the new CIM
    The final step is to calibrate the steering angle sensor
  14. #12
    Dec 2009
    EU
    I have the same problem but what if i have secondhand Cim without code from ebay....?
    just use the solution above?
  15. #13
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Desolder 93c66 from your older module and put in the other one.. as cammy25 said above.
  16. #14
    Nov 2008
    Garngad
    First of all, if you reset any controller using op-com or tech 2, then all that happens is that the security code is erased,the original settings and configurations remain the same.Second hand cims can be reset and reconfigured, the only controller that cant be reconfigured is airbag.cim takes a fair bit of configuring,i use tech 2 and and only work on VX , but still have bother at times.
  17. #15
    Dec 2009
    EU
    So i dont need to replace 93c66 just plug in secondhand CIM and reset it yes?
