here
Attachment 574929
here
Attachment 574929
claudio35 (17th February, 2019)
Dr. Zoidberg, what did you do to fix it? I also have the same problem with my picanto 2017 mb91f061bs
Did you try with softdump script?
hi
obd2 45 min no problem...thanks
I tried softdump script and it worked. You should have to reset it first before mileage programming. However, when I put it back in my car, the odometer isn't working. Its seems that the mileage is stucked. But the trip A and trip B is working
Hello everyone! I am Alexander from Softdump. Script for Denso Fujitsu MB91F Updated several times. last update is 28/01/19. If you are softdump users and you didn't get new update then write us i will create it for you
Manuelmz (28th August, 2023)
ok.very sorry
without email sure
Does anyone have connection to this cluster for UPA ? I need to pull the file out.
I just did the correction using JPROG. Mileage changed only after setting to KM and programming to 0 km, then the desired number.
Thing is.... now mileage is not counting. Trip A/B is OK.
Any tip or experience?
You should drive it around 30Km or more and it will automatically starts to count again
guys do you have a pinout for this dash please ?? thanks
If i was helpful DONT forget the THANKS and REP button
PINOUT JUST LOOK AT PCB LUCK
SAY THANKS NOT COST ANYTHING : guiņo :: guiņo :: guiņo :: guiņo :: guiņo:
