Results 1 to 9 of 9
    chakahafed's Avatar
    nouakchott
    Default SID307 SID310 is it possible to read write with PCMFLASH
    Hi every one
    I have two cars to read ECUs
    MECEDES A class 176 Wtith a Siemens Continatal ECU SID307
    Nissan Patrol with Siemens Continatal ECU SID310
    Can some one confirm that if i purchase next tools i will be able to read write them :
    - PowerBox for PCMFlash
    - Bosch EDC17-MED17 GPT cable
    - Tricore cable
    - PCMFlash
    - PCMFlash software modules : Module 25
    - PCMFlash software modules : Module 59
    i already have AVDI original as J2534 as passthrue interface
    thanks advance !
    Member rh03's Avatar
    Jul 2017
    France
    Hello, contact grezlo on the foum he is reseller of this product
  3. The Following User Says Thank You to rh03 For This Useful Post:
    chakahafed (26th November, 2018)
    Above sea-level
    I know PCMFLASH can read mercedes sid307 by obd, but I do not know if it can write via obd. Did anyone try?
    Dec 2015
    Hello to all.
    I know this is an old topic, but chakahafed, did you solve your problem with SID307 and these 2 modules - 25 and 59?!
    How to read password from SID310 with PCMFlash? With Module 59 I can read only flash. I need eeprom content.
    Above sea-level
    PCMFLASH reads SID310 file by obd correctly, but most likely writing will not work
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by budG60 View Post
    SID310 works like a charme...
    On Renault works like it should work...
    Above sea-level
    Renault works fine indeed, but not with mercedes!
    Quote Originally Posted by figani View Post
  10. #9
    figani's Avatar
    Feb 2018
    one of the reason why it not work, is why Oleg called module 59 Renault Nissan UDS...
    so it has to work wit Renault Nissan...
    and yes it works 100%...
    nothing more and nothing less...
