Results 1 to 4 of 4
Hybrid View
    Nov 2018
    Default Help to understand different cables for KESS and help to read Alfa 156 1.8 TS 144hps
    Hello, I am new and very much interested in chip tuning, so I bought KESS with a bunch of different cables and I need help to understand when and where to use them.( I put pictures of the cables that came with the KESS, down in this thread ) I also need help to connect KESS to my Alfa Romeo 156 TS 144hps to read the ECU and download the map. I've seen some manual but have no idea what cables to use and which pin to connect.
    Thanks in advance!
    dodge69's Avatar
    Mar 2012
    Belarus
    there everything is just a friend. You open the program and choose kess or katag. Next you select the block and the memory you want to read! Then there will be a window where you choose the reading parameter and you will have pinout of this block and which wire to use. help you must have files. If you do not have these files write to me and I will send you them
    thank you if I helpedgratitude motivates me to help further
  3. The Following User Says Thank You to dodge69 For This Useful Post:
    Sedimalko (27th November, 2018)
    Nov 2018
    When i press the model for this alfa it gives me 3 available guides:
    Operating Instructions
    Standart OBD II Cable
    Universal Cable
    I have those cables but on 1st picture its red, i don't know which red and what pin to put. On those manuals there is no more information where to put those cables.
    I would be very grateful if you could send me extended manual or at least explain which cable is going where. Thanks for the answer above
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Thumbs up
    mate, maybe there stays a explanation about the whole story...?
    When I helped you press Thanks and Reputation...
  6. The Following User Says Thank You to figani For This Useful Post:
