alexgelt (26th October, 2019)
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
alexgelt (26th October, 2019), carsandkeys (27th November, 2018)
EC15 is the correct pin code. Thanks
kiszka (27th November, 2018)
Please may I get a pin for this Valeo BSI dump from 95128,thanks,regards
Do what you can with what you have .
unable to read pin from your file. read ecu
need help
now my goal is to buy xp-005
who will help?
ecufix (23rd December, 2018)
Hi Rafal hope you can help ,it all started with the wipers not working,cut a long story short I flashed the 9s12 with a dump from a trusted guy and now the car is now configured as an automatic,I am trying to get the pin so that i can get a virginized bsi dump and try start the car again ,main problem is that i only have a kts and launch , no planet,thanks,regards
It is a Valeo BSI 2004 P07
you flashed the 9s12 with a dump of what?
what car is it?
need help
who will help?
It is a 207 Bsi 9659285480 2004 p07-00 kfu engine
Attached orig and supplied dumps for the 9s12, the Ben files are original
by me now will be the best way buy used bsi with same reference and make virgin , then recode
need help
who will help?
anyway u will need read ecu for pin
need help
who will help?
Hello. Can you Help me? Car is Fiat Scudo 2007. BSI N 9663798380 valeo bsi 2004 p07-00.
I need change BSI. I have same with same number. I also need make virgin another BSI. Witch I need to do this, put ff in all dump or just replace pin code and with diagbox make all adaptation?
Please Help.
Thanks in advance.
