Hi.
nothing seen in screenshot.
Hi!
I need working solution for DPF OFF on Subaru Forester 2.0 D 150HP Boxer file that does not make faults in abs module.
Yes if I write ori no fault in abs module all ok. If i write dpf off then fault appear one more time
If i write dpf off (manual or swiftec) i got an error in ABS module:
C0057 - VDC control interuption beacouse of engine instructions
Anyone know the solution?
Ori file readed from ecu in atachment. (car was tuned before)
>>Genuine Winols, Swiftec, Ktag, Flex, x17<<
>Diagnostic, Chiptuning, Dashbord<
Hi.
kubuswujo (29th November, 2018)
Johak on you file i got other fault in abs module:
C0047 - Improper CAN communication
i write once more ori file and no faults in abs. one more time your file and exist dtc.
any one other idea, what it can be?
I wrote a file with only temperature linearisation change and got also fault in abs:
C0057 -VDS control interuption beacuse of engine instruction
WTF?
