her are some file dash and bcm if thats what you looking for..
Hello,
I read the actual value then i modified 95640 in BCM with dp4.
After reading 2nd time to check, the value was 999999
I restored original file back but still reading 999999 on machine
I put the bcm back in truck and it displays 0 on the cluster.
I mofified the cluster with higher value to see if bcm records it but NO, the cluster records 0km immediately after plug in.
The car start whiout probleme
Drove truck for 30km.
Both cluster and BCM read 30km
Modified BCM again and same scenario 999999
I put BCM back in truck and it overwrote the 30km from cluster to 0.
Truck starts and evrything works
I need 163123 if someone can
I will try to inject it somehow
Thanks and Best Regards
HELLO
i put the original file bcm
ori mod 163123km
Iveco only.
HELLO
Some one can change the mileage whitout password because it is ugent!!!
best regard
HELLO
solved
i have restore the dump in another eeprom and change the mileage whit DP4 and i have remove (i have a lot of error in circuit) eeprom nano 95640 and restore whit upa programmer
all is ok
tahnk to all
best regard
i need help please need change km 63211 thanks
