YOUR FILE PASS IN PM
biya (1st December, 2018)
After the test the current regeneration message did not light but the car is still regenerating
Try.
Good luck.
biya (3rd December, 2018)
Hello
After flash write the engine will not start
Can you start car with original flash?
Maybe you have problem with checksum?
Yes the engine starts with the original flash
What soot value now?
Before flash mod file perform dpf replace and reset oil/service.
Only manual solution works, ADS no good for this ecu
OK Thank you have a manual solution ?
No solution for this ecu ?
If you want try.I do my best.Let your flash tool make checksum.By the way in your original file checksum is not ok.
Good luck
biya (6th December, 2018)
Same problem the vehicle makes the regeneration of the fap
hello
test and report
pass in pm
Chiptunning all stages
Egr. Fap/DPF. Torque Monitor disable. CVN Bypas
DTC removal. AdBlue . Hot Start Fix. Speed Limiter. Lambda remove.
MAF remove. TVA remove. Flaps/swirl flaps
biya (9th December, 2018)
After writing the file the engine does not start. thank you so much
