Page 4 of 31 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 455
  1. #46
    jodge's Avatar
    Mar 2017
    What about the fails of this tool?how many fails have you had?
    This tool costs £100.
    1 token £4
    Is too cheap to do such a good job!
    This is my opinion, that's why I still don't own it!
    i wonder why don't integrated with in the VVDI yet... clearly it's an Xhorse product at least the GUI...
  2. #47
    H.Wessel's Avatar
    Quote Originally Posted by jodge View Post
    Easy, it's a back door on servers and nobody know how many time it will take till it doesn't work... I think that is not a life time solution...
  3. The Following 2 Users Say Thank You to H.Wessel For This Useful Post:
    Maartinj (23rd October, 2019), p1et (25th April, 2019)
  4. #48
    Jun 2018
    Comizelu I had no fails until now with Vag Helper.
    The purpose of tool is to extract the CS an pincode. I receive a txt file every time with CS, pincode and VIN.
    Takes 1 - 5 minutes....need good internet connection.
    For 100 quid I think vag helper is amazing.....at least for now.
    I will try from now on VAG 2009+ no more removing cluster and only vag helper.
    For sure I Will let you know if i have any fail.
    I am pretty sure this obd helper cable will calculate immo and pin on any MQB.
    Key learning and preparing is a different question and it depends on the tools you have.
    Its too cheap - I agree with you and I still cant believe it but as long as it works I would rather take it
    I mean 2017 citigo
    picked, cut the blade,
    prepare and learn the key - vag helper + avdi immo4/5 function
    learn remote - x100 tool
    cash in and run to the next job
    20 MINUTES !!!!!!! and thats because the guy coulnt find his card.....
    Its amazing how you invest hunderds or thousands into the tools and one day something like this shows on the market....
    But you need to go with the flow
  5. #49
    autochei's Avatar
    Mar 2013
    romania
    Quote Originally Posted by harciogu View Post
    I mean 2017 citigo
    citigo it s magneti marelli dash so no need working key avdi done without vag helper fvdi same
  6. #50
    Hampshire
    It would be interesting to know if it works on none MM clusters, without removing the dash, surely if we get the CS without cluster removal, is like buying the key from the dealer?
    Harciogu, was the key normal hu66?
  7. #51
    Hampshire
    Sorry double post.
  8. #52
    Mar 2009
    Didnt work on AKL Audi A3 2009.
    Works on most other VAG I tried.
  9. #53
    Mar 2018
    UK
    is it still working ?
    can this tool do VDO after 2009?
  10. #54
    Jan 2016
    2017 and up these are Nec based clusters so no go like Marelli I suppose ??
    Quote Originally Posted by autochei View Post
  11. #55
    Dec 2017
    did somebody tried vag virtual cockpit ?
  12. #56
    super jumbe's Avatar
    Livingstone
    Any one got good reputable company name to buy vag obd tokens?
  13. #57
    Sep 2015
    Washington, DC
    Quote Originally Posted by super jumbe View Post
    http://www.xhorsevvdi.com/wholesale/...bd-helper.html I usually order a 10 pack for $46.50
  14. #58
    fred77's Avatar
    Jun 2019
    Stay away from Fly, stick with XHorse.
    another fly product. Tm100 must be fixed now?
    http://www.uobdii.com/wholesale/tm10...MaAgTvEALw_wcB
  15. #59
    I have a question.
    When you make All keys lost on MQB platform, it will calc all needed CS (Cluster CS, Engine CS, Transmission CS if present) ?
    Or it calc only Cluster CS and you have to read manually other needed CS (Engine, Transmission) ?
    Thank you
  16. #60
    Apr 2019
    At the last attempt to make a key with the VAG OBD Helper, an error 8145E occurred during the calculation. Has anyone encountered such an error? Car is new VW Tiguan 2019 Virtual Cockpit.
    There were no problems before with same cars.
