In that case does it do virtual cockpit?
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
Meat-Head (2nd December, 2018)
I have also ordered this cable.
I will post soon results
p1et (2nd December, 2018)
Anyone already tested it??
i found this VAG OBD helper here:
http://www.uobdii.com/wholesale/vag-obd-helper.html
And there is a article show a guide on How to use VAG OBD helper + K518ISE to program VAG 4th / MQB key?
http://blog.uobdii.com/how-to-use-va...g-4th-mqb-key/
As I know, it is not from Xhorse, but from a senior locksmith.
He says he test it can extract VAG 4th immo data that any of VVDI2, Lonsdor, AP-Pro is not easy to do.
He also makes guide on how to use it with VVDI2, Lonsdor.
google and you will see some vidoes and blogs offering the guide.
Firstly read VAG 4th immo, then with the data to program key with VVDI2
https://www.youtube.com/watch?v=lVYqe7IJJjc
Firstly read VAG 4th immo, then with the data to program key with Lonsdor K518ISE
Guide
yes i just saw this today
apparetnly it is meant to assist in getting you the data you need to do the job and is meant to HELP
http://blog.obdii365.com/2018/11/26/...k518ise-vvdi2/
Functions:
1: Support A4L Q5 (all the card 754C/J type)
2: can be used for VW, Audi, Skoda key making (even when all keys lost) and the 4th generation odometer correction.
Example, 35XX key all lost 873B 24C64 type key all lost or new model 95320.
3:can add key for MQB JOHNSON dashboard (not support key all lost )
4.New PASSATT MQB key all lost.
5.Support to get BCM2 anti-theft data online for A6 A7 A8 Touareg Phideon with 5th immo.
When to use VAG OBD helper?
1. For the VAG vehicle with MQB immo, if the immo data can't be read out, you can try to use VAG OBD helper, but can work for adding new keys (Take Johnson Controls key adding for example)
2. If A4L Q5 can't be directly read out BCM2 data, and display the data length error, VAG OBD helper can be used to calculate BCM2 data.
3.If you get all keys lost for any of 2014 A6 A7 A8 Touareg, PHIDEON with 5th immo system, you can use VAG OBD helper to online calculate BCM2 data, then working together with VVDI2, APPRO to program key.
Note: Before using VAG OBD helper, please make sure the vehicle info is not tampered and vehicle status is legal, otherwise the immo data can't be calculated.
I am thinking of buying vvdi2 and helper, instead of updating my avdi bcm2 function, can anyone (who has done a Audi bcm2 lost key via obd)), confirm that vvdi2 can do it safely via obd? obviously the helper can increase this chance? maybe upto the version where bcm2 has an eeprom?
My guess is that the online keylearning on vvdi2 stands for vaghelper.
It is not activated yet,
And Will probable free to full package owners, or token based.
No one has tried a upgraded bcm2, or none eeprom version?
After recived this tool, i tried on golf 7 2013 SW 0555.
dyzio (17th December, 2018), nazz2 (25th December, 2018), p1et (17th December, 2018), Stelaras26 (11th November, 2019), u.s (18th December, 2018)
Yes it was on real car.
I will make next time a video, maybe the server was bad... because i tried couple of times to read car info, it fails and i get time out for 3 hours.
I tried after 3 hourse again and i succeed to read car info but online calculation failed.
So maybe just bad luck
its look like direct reeding immo data in abrites avdi but in abrites you need to connect to can antrieb not obd and works ok in ori version
Any new reviews?
2006 Audi A3....failed. could not even see car.
