Page 2 of 31 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 455
  1. #16
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    In that case does it do virtual cockpit?
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
  2. The Following User Says Thank You to z786 For This Useful Post:
    Meat-Head (2nd December, 2018)
  3. #17
    Dec 2017
    I have also ordered this cable.
    I will post soon results
  4. The Following User Says Thank You to shotaaa For This Useful Post:
    p1et (2nd December, 2018)
  5. #18
    Aug 2015
    Anyone already tested it??
  6. #19
    May 2017
    i found this VAG OBD helper here:
    http://www.uobdii.com/wholesale/vag-obd-helper.html
    And there is a article show a guide on How to use VAG OBD helper + K518ISE to program VAG 4th / MQB key?
    http://blog.uobdii.com/how-to-use-va...g-4th-mqb-key/
  7. #20
    Jun 2016
    Quote Originally Posted by sleepyrz View Post
    its not another company
    its just xhorse
    it looks like its just a vag cable for vvdi2????
    As I know, it is not from Xhorse, but from a senior locksmith.
    He says he test it can extract VAG 4th immo data that any of VVDI2, Lonsdor, AP-Pro is not easy to do.
    He also makes guide on how to use it with VVDI2, Lonsdor.
    google and you will see some vidoes and blogs offering the guide.
    Firstly read VAG 4th immo, then with the data to program key with VVDI2
    https://www.youtube.com/watch?v=lVYqe7IJJjc
    Firstly read VAG 4th immo, then with the data to program key with Lonsdor K518ISE
    Guide
  8. #21
    Jan 2017
    USA ����
    yes i just saw this today
    apparetnly it is meant to assist in getting you the data you need to do the job and is meant to HELP
    http://blog.obdii365.com/2018/11/26/...k518ise-vvdi2/
    Functions:
    1: Support A4L Q5 (all the card 754C/J type)
    2: can be used for VW, Audi, Skoda key making (even when all keys lost) and the 4th generation odometer correction.
    Example, 35XX key all lost 873B 24C64 type key all lost or new model 95320.
    3:can add key for MQB JOHNSON dashboard (not support key all lost )
    4.New PASSATT MQB key all lost.
    5.Support to get BCM2 anti-theft data online for A6 A7 A8 Touareg Phideon with 5th immo.
    When to use VAG OBD helper?
    1. For the VAG vehicle with MQB immo, if the immo data can't be read out, you can try to use VAG OBD helper, but can work for adding new keys (Take Johnson Controls key adding for example)
    2. If A4L Q5 can't be directly read out BCM2 data, and display the data length error, VAG OBD helper can be used to calculate BCM2 data.
    3.If you get all keys lost for any of 2014 A6 A7 A8 Touareg, PHIDEON with 5th immo system, you can use VAG OBD helper to online calculate BCM2 data, then working together with VVDI2, APPRO to program key.
    Note: Before using VAG OBD helper, please make sure the vehicle info is not tampered and vehicle status is legal, otherwise the immo data can't be calculated.
    The thanks button is HERE looks like this --->>> THANKS
  9. #22
    Aug 2009
    Hampshire
    I am thinking of buying vvdi2 and helper, instead of updating my avdi bcm2 function, can anyone (who has done a Audi bcm2 lost key via obd)), confirm that vvdi2 can do it safely via obd? obviously the helper can increase this chance? maybe upto the version where bcm2 has an eeprom?
  10. #23
    rob h's Avatar
    May 2011
    My guess is that the online keylearning on vvdi2 stands for vaghelper.
    It is not activated yet,
    And Will probable free to full package owners, or token based.
    No one has tried a upgraded bcm2, or none eeprom version?
  11. #24
    Dec 2017
    After recived this tool, i tried on golf 7 2013 SW 0555.
  12. The Following 5 Users Say Thank You to shotaaa For This Useful Post:
    dyzio (17th December, 2018), nazz2 (25th December, 2018), p1et (17th December, 2018), Stelaras26 (11th November, 2019), u.s (18th December, 2018)
  13. #25
    Sep 2016
    Quote Originally Posted by shotaaa View Post
    It was on real car? There SW version dosent matter. Important is only FAZIT ID and VIN.
  14. #26
    Dec 2017
    Quote Originally Posted by qeso705 View Post
    Yes it was on real car.
    I will make next time a video, maybe the server was bad... because i tried couple of times to read car info, it fails and i get time out for 3 hours.
    I tried after 3 hourse again and i succeed to read car info but online calculation failed.
    So maybe just bad luck
  15. The Following 2 Users Say Thank You to shotaaa For This Useful Post:
    p1et (23rd December, 2018), qeso705 (30th December, 2018)
  16. #27
    Dec 2017
    its look like direct reeding immo data in abrites avdi but in abrites you need to connect to can antrieb not obd and works ok in ori version
  17. #28
    Sep 2016
    Any new reviews?
  18. #29
    Mar 2017
    2006 Audi A3....failed. could not even see car.
  19. The Following User Says Thank You to ps80l For This Useful Post:
  20. #30
    Nov 2018
    Quote Originally Posted by ps80l View Post
    i wonder what happens if a "force ignition on tool" was used between the obd and obd helper for that car. like a toureg.
