Results 1 to 5 of 5
Thread: ktag problem
    jamienatorr's Avatar
    May 2018
    Default ktag problem
    Does anyone have ksuite 1.85? I have a problem with my ktag - checksum error when reading a flash and I can not deal with it.
    I've tried literally everything. Replacing dll C ++ installation and others.
    dimitar's Avatar
    someone before flashed the ecu with another tool and corected checksum
    use galleto or mpps because ktag and kess wont help
    There is a patch lurking around the net which disable ktag checksum correction in order to read and write all ecus but you need to corect checksum before writing
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  3. The Following User Says Thank You to dimitar For This Useful Post:
    jamienatorr (3rd December, 2018)
    May 2018
    Quote Originally Posted by dimitar View Post
    unfortunately I do not have galleto or mpps. I ordered a simple bdm100 yet. Thanks, mate!
    mancioks's Avatar
    Feb 2017
    Germany
    I had same problem with Ktag and EDC17C19, could not read it with kess and ktag tricore. Found ori file with same numbers and write on it. Then read again and make mod.
    May 2014
    LIthuania
    Quote Originally Posted by mancioks View Post
    Sometimes it's symptoms of edc16 malfunction in flash 29BL802 I had 3 times personally
    Išsiųsta naudojantis HUAWEI TIT-L01 Tapatalk 4 Lt
