Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Mar 2010
    Default Opel Astra J 2011 Electric Steering Module Virginise
    Does anyone know if it is possible to Virginise or Edit the VIN in the Electric Power Steering Motor/ Control Module?
    I have removed from Donor Vehicle with SPS Ok but it has retained the VIN.
    It will not Reprogram to the New Vehicle with SPS due to the fact the VIN is still stored.
    I have Looked at Module with AVDI (Genuine Licensed) and can see the VIN, there is also an option to Edit VIN but this does not work.
    Before i start and Cut the Unit open (Can't see any other way) was looking for a heads up if it is possible.
    Tried with a similar unit on a Land Rover and no jo bb
  2. The Following User Says Thank You to accchris For This Useful Post:
    trafas (1st March, 2021)
  3. #2
    Aug 2009
    poland
    Hello, I have the same problem, dooes you find solution of this problem?
    Mar 2010
    No, I have not found a Solution yet. I have stripped Motor down to gain access to ECU but it is a Hybrid Type no Obvious way to read it.
    Sep 2015
    You can change the VIN by FVDI. I did yesterday it works. After change VIN you have to learn the steering angle sensor.
  6. #5
    Mar 2010
    VVDI or the Cheap FVDI?
    Tried with AVDI Genuine and although the option to change VIN was there it would not allow to change it.
  7. #6
    Jul 2018
    FVDI 2018 working 100% vin changed
  8. The Following 3 Users Say Thank You to sikeens For This Useful Post:
    accchris (26th September, 2020), trafas (25th February, 2021), wiseman (8th March, 2021)
  9. #7
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    hi frends
    i have the same problem with astra j
    after change power steering
    how too change vin on new one??
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
  10. #8
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    problem solved
  11. #9
    i_shot_the_sheriff's Avatar
    Nov 2008
    Solved with fvdi ???
  12. #10
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    yeah FVDI fix it
    Quote Originally Posted by i_shot_the_sheriff View Post
  13. The Following User Says Thank You to robert1232 For This Useful Post:
  14. #11
    Jul 2010
    FRANCE
    FVDI OK AND AVDI NO WORK !!!
    I HAVE THE SAME PROBLEM WITH MY AVDI OFFICIAL !!
    OUAH !!!
  15. #12
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by durdur View Post
    OUAH !!!
    is that possible? (in original avdi need the opel license maybe?)
  16. The Following User Says Thank You to Panathaole For This Useful Post:
    robert1232 (26th October, 2021)
  17. #13
    Mar 2010
    Yes Original does not work, but FVDI does.
    Like quite a few Functions, Original is not very good and getting worse, Not better.
  18. #14
    Jul 2010
    FRANCE
    Hi everyone,
    the best is if the official Abrites France seller tells you that it is possible and that you have to buy an FVDI or send it the Logs. What after-sales service for material at this price !!!! I am disgusted
  19. #15
    Jul 2010
    FRANCE
    Good morning all,
    therefore with AVDI it works on table in direct connection.
    Here is the doc I made.
    You would have to try it on the car by plugging in can-h and can-l live.
  20. The Following 9 Users Say Thank You to durdur For This Useful Post:
    all4 (23rd May, 2022), aprilia40 (29th November, 2022), dawidhubert (17th July, 2023), Duraid1 (13th May, 2022), gomarota (20th October, 2021), henal (8th April, 2022), lysy020 (29th November, 2023), trafas (23rd February, 2021), wiseman (8th March, 2021)
