Results 1 to 6 of 6
    Sep 2008
    Default Recording from dm500C to dm800s
    Just received my new DM800 HD sat. I also have a DM500c.
    I have also bought an external HDD e-sata to connect to the DM800 for recording purposes.
    Is there any way in which I could record programmes from the DM500 to the DM800 setup?
    I have only one Netgear WG602 access point which is next to both and which I use to connect both (obviously not at the same time) to my wireless network.
    hi
    did you manage to get this working?
    cheers
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Quote Originally Posted by bauhaus View Post
    Assuming that you can network both of your dreamboxes than you could mount the dm500 onto the dm800 hdd similar to mounting it to pc hdd and record programmes.
    Sep 2008
    Hi Curious123
    Unfortunately I can only connect one DB to the network at a time.
    It's however a good tip if I can get another cheap access point.
    Cheers
    Sep 2008
    Quote Originally Posted by punter987 View Post
    hi
    cheers
    See above.
    At the moment I am using a Thor AV Control Center which allows me to record on a VCR. Not ideal but at least the children are happy!
    Dec 2009
    Default drembox dm500-s
    why i can`t download dk?.
