Results 1 to 3 of 3
    Jan 2018
    shaftesbury,Dorset,UK
    Default VNT15 turbo pd100/115 with pd130 injectors any more power
    car has pd130 injectors installed but has stock VNT15 turbo that comes with pd100/pd115 the injectors were limited to 165bhp i believe and now have changed the injectors
    can the turbo cope with any more power? can anyone add power to it even with smoke?
    car has straight pipe exhaust. Turbo makes weird cooo noises when throttle is let off currently
    I have been reading online that this turbo can make 30 psi with ok-ish reliability.. would the side mount be o.k at this pressure?
    thanks guys
    038906019DD SG1518
    ATD (100 bhp/240 Nm)
    calibracbr's Avatar
    Aug 2015
    Moon
    I see your pressure it is 1.2 bar, I would not go with this turbo over 1.6bar.
    Very poor tuned.
    If you need a st2 i can help.
    Mar 2016
    p100 injctors can give 180hp.
    Stock turbo is good for 1.4bar at 2000rpm, 1bar at 4000rpm.
    Don't go over 1.5bar, because map sensor only reads until 1.6bar of boost.
