use 03G906016KN DPF+EGR OFF it works
Hello
I need to check if the DPF has been removed correctly from AUDI A4 2.0 TDI BPW 140HP
In the second version of DPF OFF together with EGR OFF.
If the maps have been wrongly done, you will be asked to improve them in 2 versions DPF OFF and DPF + EGR OFF
Can I upload these files directly to the memory or I need to correct the checksums.
Please help because dpf dumped and Ecu shows the error.
Don't forget hit thank button if i helped.
dpf swich only need this 01 AD 7F FF 80 00 00 00 02 8F 01 Stock 01 AD 7F FF 80 00 00 00 02 8F 00 DPF Off
You know that only delets your dpf error code and that is not a right dpf off...
you can check , only need this
