780 no net id
Results 1 to 7 of 7
Thread: 780 no net id
    Sep 2018
    Default 780 no net id
    had to reset my daughters 780, but cant get no channals or net id for scan, in put for cardiff 75500 6887 64 qam on manual and network, no splits been used, i have searched and read other threads, but no joy, any ideas guys..thankyou
    Feb 2010
    go into menu > preferences > sat Tp edit >choose NTL if that's your area right click on volume > delete TP`s one at a time when empty >
    then insert manually with remote TP 651.00 > SR 6952> QAM 256 save
    then press menu button again yellow button Press search, if nothing happens try again then press green see if area netid appears? hopefully something will kick in let me know.
  3. The Following User Says Thank You to ASEK For This Useful Post:
    666 (3rd December, 2018)
    May 2008
    thankyou very much m8, spot on i was putting in 75500 6887 256 all up and running
    Feb 2010
    No problems.
  6. #5
    Dec 2008
    Default A780
    Quote Originally Posted by aka666 View Post
    I also have no luck in net id for Wolverhampton or channels any help would be greatly appreciated
  7. #6
    Dec 2008
    I also have the same issue with net id and channels
  8. #7
    Feb 2010
    Well if you follow my post it might help?
