Results 1 to 3 of 3
    May 2017
    Default EDC15C7 Delete P0601
    Hi, I have a Peugeot Boxer 2004 ECU EDC15C7, which had immo box damaged (eeprom lost).
    at the beginning I do immo off on flash and the vehicle starts but the engine check light is lit in red,
    I found another eeprom of the immo box, I wrote an original dump + program two keys, I put the original flash ecu + virgin eeprom ECU
    everything is fine except the Check Engine Light,
    I have a dtc P0601, the vehicle works perfectly,
    I want to remove this dtc
    gege974's Avatar
    Oct 2018
    réunion island
    your flash does not match your eprom file
    Small circumstances produce great events : 02.47-tranquillité:
  3. The Following User Says Thank You to gege974 For This Useful Post:
    MYMN (5th December, 2018)
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Here it is.
  5. The Following User Says Thank You to konq100 For This Useful Post:
