Results 1 to 15 of 20
    cotymoto's Avatar
    May 2009
    Default Ford focus edc16 0281015242 bricked to read mpps
    Hi problem with ecu 0281015242. Bricked to read by obd. Now read for bdm good but to try write always error checksum. ( when read backup need send file to alientech for activate to recognize ecu ). Not identify ecu to write and always appear. Try write map. Error. Try write backup error size file. . Need help please thanks you. Have file map oem read for ksuite. Need full file read with ktag correctly I think. Thanks.
    Enviado desde mi SM-G950F mediante Tapatalk
    alonedark's Avatar
    Feb 2017
    briked when you read or when you write, i think when you write , i think you read only partial map by obd and when you write do nt have full file, i think you need full file and write by bmd , thi ecu is 1.6 d edc16c34????? put hw and sw number and you look origina full bdm file and write by bdm
    cotymoto's Avatar
    May 2009
    When write file. With mpps. This car have file original and modify. The 2 read for obd. Now can read with bdm ktag full. But not write. I don't what is the problem . Not identify ecu and appear error file to restore. . What I can do. if you read me full bdm file but do not write because it does not identify ecu
    alonedark's Avatar
    Feb 2017
    put sw and hw of the ecu, need full flash original
  5. The Following User Says Thank You to alonedark For This Useful Post:
    cotymoto (5th December, 2018)
    cotymoto's Avatar
    May 2009
    Quote Originally Posted by alonedark View Post
    Need help the full flash ktag ecu 0282015242 ford. How put sw and hw of the ecu. I can read. But not write bdm. Not understand.
    carmageddon's Avatar
    Italy
    write here SW number or send here your readout
    ASCM's Avatar
    Oct 2018
    Default BDM
    BDM FORMAT
    cotymoto's Avatar
    May 2009
    Quote Originally Posted by carmageddon View Post
    The hw is 0281015242 and soft. 1037395209. Now send all read in backup.
  10. #9
    alonedark's Avatar
    Feb 2017
    Héroe You have, write flash file by bdm https://www.digital-kaos.co.uk/forum...ght=1037395209
  11. #10
    cotymoto's Avatar
    May 2009
    Default full bdm ktag
    here have all backup read with ktag friend. the problem is not recognize ecu but i can read, not understand
  12. #11
    alonedark's Avatar
    Feb 2017
    you have flash file of the ecu bad , need write by bdm flash file, you can try whith ktag but i dont khow if ktag works, only need flash file , you have partial flash in ecu need full file
  13. #12
    alonedark's Avatar
    Feb 2017
    if you compare in hex you flash file and the other one you can see ,you have many FFFFF and the other one you have the file for example here
  14. #13
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I had same problem flash was erased partial you need full flash to write with bdm 100 not over obd In my case software was saved but maps area was all FF FF . So full flash with same soft number +cks and write via BDM .
    Here to HELP!
  15. #14
    cotymoto's Avatar
    May 2009
    This car has been deleted by dpf more than 1 year ago and that's why I have OEM Flash. but I can not write it because it does not recognize the ecu and I see the image that e Sent. someone can help with full bdm. Hw and soft. Thanks friends.
  16. #15
    cotymoto's Avatar
    May 2009
    Quote Originally Posted by immokill View Post
    You how solvent this problem inmokill
