Semi blocked exhaust.. EGR ??? If it is EGR walk away.
Good day need advice on a 2012 Vw Polo 6R engine light comes - DTC shows Air Mass meter intermittendt signal - after cancel it activates after a while the engine light again - checked all wiring seems good - even changed the air flow meter with a another 1.6 TDi vehicle same error comes back on - any advice be appreciated
'If I helped, please click Thanks +Reputation.. !'
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
error code is P010100 - would replacing the egr cooler be a solution or even try to clean out the diesel soot
