There are many versions. how to activate?
ahmedsawalhy (13th December, 2019), smilos (9th October, 2019)
Hi guys !
I explain my issue:
I'm trying to program a second key card (virgin) for my scenic 2 ph 2.
I have DDT 4 ALL, and now Renolink 1.49 thank to members here.
With DDT4ALL, i can talk with the vehicle with my obdlink SX interface. But impossible to enter APV mode, it says : BAD ELM RESPONSE : WRONG RESPONSE CFC0 UNKNOWN.
So i tried with Renolink this afternoon.
Interface is recognized, but when i try to communicate, it says wrong interface...
I tried to change baud settings to 1000000 but it is worse, interface is no more recognized...
If anyone has an idea... ?
With ddt4all we can test the OBDLink SX interface.
If dd4all detects bad interface it may be that the interface is down!
you have to try with another interface to remove the doubt.
You can't use ddt4all to program a new key because the pin given by ddt4all is not right. You can not access after sale mode and can not add a key.
I programmed few days ago a new key for my scenic 2 pH 2 using a renolink interface 1.49, from China. You should first get the right pin then enter in after sale mode. Program all the keys and then validate.
You have to go to Misc/Key/ choose Uch scenic 2, then connect. If all is OK you can see and copy the pin.
Then return to the main soft and find the Uch ecu (uch_84_j84...) then go to after sale. Copy the pin in "code apv" and push "armer mode apres vente". You can now program your keys.
For me it worked
Envoyé de mon Redmi Note 6 Pro en utilisant Tapatalk
Hello friend!
Pleas pass!
Thank you!
Originally Posted by mikroel
here is link for v1.49 activated
https://mega.nz/#!n1gByaAD!AR_N5Vxf8...yaiEeD0LLmEOOk
PASS after Thanks + Reputation
Hello friend!
Pleas pass!
Thank you!
Hi CK32,
Thanks for the explanation it is justewhat i found yesterday. I didn't hadtime to try now.
DDT4ALL is working with my interface, but with renolink 1.49activated from Mikroel, it says "invalid interface" when i try an action or to communicate, but i can see interface detected...
I will try again tomorrow...
[DEVIS = benkiller77; 3630676] Bonjour
, cela fonctionne avec DDT4ALL [/ QUOTE]
I wrote a little tutorial to teach Startup / Opening Cards for my Espace IV Ph2.
It also works for other Renault and may be other brands, to check!
I used an older version of Renolink, the 1.49 and a USB-OBDLink SX red interface cable.
Depending on the version of Renolink, use a blue or red cable!
I bought a map on Ebay, it's a Chinese copy.
I hope it will help you !
benkiller77 (26th July, 2019), Col19 (11th December, 2019), conan981 (15th October, 2019), crazylou2017 (2nd August, 2019), florin_leo (3rd January, 2020), haroun (2nd August, 2019), rhj (25th September, 2019), zeca (15th May, 2022)
Thank you Jeanalvitre
DO you also have the password for the archive ?
I also have 1.49 renolink and red cable so like you and every other people it should work...
Hi guys, i show you the problem with a screenshot :
Interface seems recognized but on any action it says invalid interface.
Any ideas ?
Don't change latency, let it 16ms
