Page 18 of 61 FirstFirst ... 8131415161718192021222328 ... LastLast
Results 256 to 270 of 902
  1. #256
    Feb 2019
    Quote Originally Posted by nacar View Post
    can i have pass please
    For version 1.49 downloaded on here ?
  2. #257
    Jun 2018
    Hello,
    For programming a Renault Megane 3 with keyless system, is required some special procedure or just like the normal one?
    Thank you!
  3. #258
    Mar 2016
  4. The Following User Says Thank You to pakoto For This Useful Post:
    Col19 (11th December, 2019)
  5. #259
    sdnatlst's Avatar
    Aug 2011
    England
    trafic 2014+ key programming supported on the 1.72 version?
    which cable do you recommend?
    Tools owned -
    AD100 PRO, Lonsdor, FVDI 18, FVDI 20, VVDI PROG, VVDI2, VVDI MB
    CGDI BMW, SuperVag, Renault ECU tool, OBDstar X300 DP Plus, AUTEL im508
    VVDI Mini Keytool, KeyDIY KDX2, SBB, ACDP CAS/KVM
    Opcom, VCDS pro, Diagbox, Multiecuscan, Forscan, JLR SDD
  6. #260
    Jun 2019
    hi my frind how are youe
    pleas code archive renolink V1.67
    Quote Originally Posted by jolor View Post
    Here V1.67....works with blue and red cable.
  7. #261
    Sep 2016
    password for renolink 1.67 pls
  8. #262
    Aug 2009
    Quote Originally Posted by mikroel View Post
    here is link for v1.49 activated
    https://mega.nz/#!n1gByaAD!AR_N5Vxf8...yaiEeD0LLmEOOk
    PASS after Thanks + Reputation
    Please can you send me the pass for it?
    10x!
  9. #263
    Apr 2012
    Here Is Renolink 1.52 Activated Full Database, Password Free.
    Good Luck
  10. The Following 11 Users Say Thank You to rabihfiras For This Useful Post:
    amor89 (6th July, 2019), Andreastech81 (11th June, 2019), aurelio (4th July, 2019), engecu1 (17th July, 2019), jeanalvitre (15th June, 2019), joe06 (9th July, 2019), lock66 (8th July, 2019), SALAS (25th September, 2019), Senex (3rd July, 2020), sep382 (8th March, 2020), xseva (22nd February, 2020)
  11. #264
    Aug 2009
    Quote Originally Posted by jeanalvitre View Post
    Obdlink SX red only work with original version or version 1.49.
    For version 1.52, only original version or blue interface..
    For me not working 1.49 with OBDlink SX.I'm not interesting about programing, only diagnostics.
  12. #265
    Aug 2009
    Please, CAN i have password?
  13. #266
    Aug 2009
    I use ddt4all and work very well on Duster SID ecu 1.5dci 110cp 4x4, end logan 1.4 ems3132.at logan worked incremetary idle rpm.
  14. #267
    yahia1908's Avatar
    Dec 2009
    RENOLINK
    https://mega.nz/#!PhhD2KxK!fgrN6qNXh...MzcC_z0pVal5S8Renolink_MultiVersions.7z
  15. The Following 7 Users Say Thank You to yahia1908 For This Useful Post:
    Col19 (11th December, 2019), florin_leo (3rd January, 2020), jeanalvitre (17th July, 2019), joe06 (18th July, 2019), laplace1050 (20th October, 2019), laurentiudania (24th July, 2020), sep382 (8th March, 2020)
  16. #268
    Feb 2019
    Hello,
    Thank you.
  17. #269
    Dec 2018
    Quote Originally Posted by yahia1908 View Post
    what is it?
  18. #270
    Feb 2019
    Quote Originally Posted by Catalizator View Post
    what is it?
    This is a file that contains 26 versions of Renolink V1.21 up to V1.71!
    I did not test!
    Thank you very much yahia1908 .
