Results 1 to 10 of 10
Thread: golf v 1.9 bkc
    Dec 2018
    Default golf v 1.9 bkc
    can please someone tell me what are those maps after boost limiter? ee4f6, ee5ea, ee6de, ee7d2, then another 4 similar after, maybe multiple boost limiter maps? if they are can please someone explain it, because i dont understand them, i have included my ori. and a mappack that i have created but not quite finished.
    Summa's Avatar
    Nov 2018
    Hi.
    EDCAC 10x16 ; EDE18 10x10; EDF64 1x1
    That is all you need to touch.
    Dec 2018
    Quote Originally Posted by Summa View Post
    Hi.
    Hi Summa, thanks for the reply, im quite experienced in tuning edc15 but this is my first go at a edc16 ecu, i have already modded all the addresses mentioned, but the problem im facing is that torque feels very limited in every gear except 5th, which is the reason i ask about those maps what im thinking is, apart from the main torque limiter, i know there is gear based torque limiters but they are all set to 3000nm by defaut so they are inactive, is there individual boost targets/limits for each gear in this ecu? i have included my modded file if you could have a look and see if you can see anything that would cause this problem.
    Jul 2017
    there is no need to touch SVBL for stage 1
  5. The Following User Says Thank You to kalisiux For This Useful Post:
    marcusbs61 (9th December, 2018)
    Dec 2018
    it is a stage 2 file my friend, hybrid turbo running 1.6 bar peak boost have to increase SVBL or this would not be possible
    Jul 2017
    I did not know your file because I am now AFK. When I get home, I'll see what you broke down
    Dec 2018
    That is no problem my friend, thank you.
    Summa's Avatar
    Nov 2018
    Hi.
    Log the car and identify the exact cause of the limitation, it is not about "how it feels" , it is about the log output .
  10. #9
    Dec 2018
    That is what i will be doing tomorrow, been so busy all week with work I've not had a chance to get any done, there is definitely something limiting though i so will get a few logs done and see exactly what the ecu is requesting.
  11. #10
    Dec 2018
    I found my problem, i had defined the axis for soi wrong, and in turn edited the wrong column causing my fueling calculations to be way out, currently fixing the file now that i have found a proper map pack for the ecu
