Results 1 to 15 of 29
    matik185's Avatar
    Jun 2018
    Europe - PL
    Post Renault/Dacia Medianav 1 Map update
    I would like to share with you solution to update maps for Medianav 1 navigation system , that you can find in Renault or Dacia system.
    Procedure is very simple and quick!.
    INSTRUCTIONS:
    1) First at all you have to update you system to 4.0.6 version - its important! You MUST have 4.0.6 otherwise you will not be able to update your maps!
    2) Second you have to update dboot in your system - it will allow to enter Windows and copy files in storage/internal memory
    3) Third you have to install securesystem - it will allow Medianav to run Windows mode
    4) Finally we will install patch, that will allow and unlock Medianav to run maps - from iGO !
    The last available maps are 2018.Q3 - you can find link in attachment.
    Prepare your maps on USB:
    .FBL, .HNR - for MAPS folder
    .POI - for POI folder
    .SPC - for SPEEDCAM folder
    Please remember that Medianav has available space around ~ 2.3 GB
    After that , only thing left is to copy maps to the memory of the system.!
    Please switch off the radio.
    Wait couple of seconds after radio will be completly switched off.
    Switch the radio ON, logo of Renault/Dacia will appear.
    When you see the logo please see on the left down corner will apper - DBOOT 1 .x . x - and when you see it please touch the screen and slide with your finger slowly by the touch screen - Popup scren will appear - CONFIRM and EUREKA! We are in the Windows!
    Enter the medianav memory. Find CONTENT folder and inside there will be MAPS , POI, SPEEDCAM.
    Just copy the maps and rest of spc and pois..
    When you will finish just switch off system by icon on Desktop.
    Restart Medianav and after that you have latest maps!
    DOWNLOADS:
    All file are attached to the post.
    Please fell free to ask if any problem will appear.
    PASS after Thanks + REP. will be send by PW
  2. The Following 49 Users Say Thank You to matik185 For This Useful Post:
    7500p (7th August, 2023), ahcen elctro (19th March, 2021), ayoubgt75 (21st January, 2019), azepako (28th February, 2024), benzouhir (25th January, 2019), bobydz (4th January, 2020), branco (10th August, 2019), Chr1sG (12th June, 2019), corfumadness (7th September, 2019), denemede (24th February, 2021), ducoskicuki7 (31st January, 2021), Dylie (1st May, 2022), dzamine670 (20th December, 2018), ferdifil (21st March, 2019), gilbert250 (29th October, 2019), gstama (26th February, 2024), hakan38 (12th September, 2019), hex48 (18th January, 2024), houdiag (13th May, 2019), ik2125 (6th March, 2024), jazz463 (22nd April, 2023), Jesuita45 (27th December, 2018), juned2 (12th September, 2019), kamelkamel (26th May, 2019), karimdiag (6th May, 2020), Kinred (28th March, 2019), LABDANI AHMED (13th August, 2019), LusitanBiker (7th July, 2021), lwd11 (30th May, 2019), matej505 (29th August, 2023), number7hd (3rd January, 2019), ouragh (17th March, 2019), pdxc (10th January, 2023), petemech (9th May, 2019), pkatra (22nd June, 2019), rickard (20th September, 2020), scorpionoir1982 (10th December, 2018), seval (17th May, 2019), silviuu (20th March, 2019), smes89 (28th September, 2019), techzeed (6th February, 2020), teed (9th December, 2018), theolamp (25th July, 2022), tito2002 (9th November, 2020), VVDI (14th October, 2019), _estima_ (24th July, 2019)
  3. #2
    Newbie Jesuita45's Avatar
    Aug 2015
    Portugal
    Boas obrigado, e mande a pass por favor. abraço
    Nov 2018
    hello friend
    need pass
    ouragh's Avatar
    algeria
    slt
    please mp
  6. The Following User Says Thank You to ouragh For This Useful Post:
    denemede (23rd February, 2021)
    Mar 2019
    Default agradecimento
    [QUOTE = matik185; 3442618]
    Eu gostaria de compartilhar com você a solução para atualizar mapas para o sistema de navegação Medianav 1, que você pode encontrar no sistema Renault ou Dacia.
    O procedimento é muito simples e rápido !.
    INSTRUÇÕES:
    1) Em primeiro lugar você tem que atualizar seu sistema para a versão 4.0.6 - é importante! Você DEVE ter 4.0.6, caso contrário você não poderá atualizar seus mapas!
    2) Segundo você tem que atualizar o dboot no seu sistema - ele permitirá entrar no Windows e copiar arquivos no armazenamento / memória interna
    3) Terceiro você tem que instalar o sistema de segurança - ele permitirá que o Medianav rode o modo Windows
    4) Finalmente instalaremos o patch , que permitirá e desbloqueará o Medianav para executar mapas - a partir do iGO!
    Os últimos mapas disponíveis são 2018.Q3 - você pode encontrar o link no anexo.
    Prepare seus mapas em USB:
    .FBL, .HNR - para pasta MAPS
    .POI - para pasta POI
    .SPC - para pasta SPEEDCAM
    Por favor lembre-se que Medianav tem espaço disponível em torno de ~ 2,3 GB
    Depois disso, a única coisa que resta é copiar mapas para o memória do sistema.
    Por favor, desligue o rádio.
    Aguarde alguns segundos após o rádio estar completamente desligado.
    Ligue o rádio, o logotipo da Renault / Dacia aparecerá.
    Quando você ver o logotipo, por favor, veja no canto esquerdo da esquerda irá aparecer - DBOOT 1 .x. x - e quando você vê, por favor, toque na tela e deslize com o dedo lentamente pela tela de toque - Popup scren aparecerá - CONFIRM e EUREKA! Estamos no Windows!
    Digite a memória mediana. Encontre a pasta CONTENT e dentro haverá MAPS, POI, SPEEDCAM.
    Basta copiar os mapas e resto de spc e pois ..
    Quando você vai terminar basta desligar o sistema por ícone na área de trabalho.
    Reinicie Medianav e depois disso você tem os mapas mais recentes!
    DOWNLOADS:
    Todos os arquivos estão anexados ao post.
    Por favor, fique à vontade para perguntar se algum problema aparecerá.
    Passe depois de agradecer + REP. será enviado por PW [/ QUOTE]
  8. #6
    Mar 2019
    Exelente post
    obrigado
  9. #7
    Mar 2019
    Could use a password
  10. #8
    Apr 2009
    Any chance of P/word -please ?
    Peter
    pkfielden@hotmail.com
  11. #9
    Sep 2016
    thank you for your efforts .i need pass pls
  12. #10
    matik185's Avatar
    Jun 2018
    Europe - PL
    write me PM
  13. #11
    Newbie seval's Avatar
    thank you very much
  14. #12
    lwd11's Avatar
    Jun 2016
    POLAND
    Hi, pass pls, thank you.
  15. #13
    Jun 2019
    Pass pls, thx :-)
  16. #14
    matik185's Avatar
    Jun 2018
    Europe - PL
    Pass for all - Medi@nav!
    I cant remember but try..
    Wysłane z mojego SM-G950F przy użyciu Tapatalka
  17. #15
    Mar 2013
    Cascais - Portugal
    Thank you for your post.
    Can you send pass please?
