Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
  1. #31
    Mar 2016
    Have to be injector problem, many times testing injectors in bench will not show its problem cause of using testing liquid solution not diesel. Please try like this, remove injector leak off pipes and put them into bottles, about 10ml per injector @ 1 minute will be roughly acceptable. I have had this problems with psa engines several times as runs and cuts out, injectors claimed to be ok(tested ok in bench @ diesel repair/testing company), but really they where shot!
  2. The Following User Says Thank You to SvenR1 For This Useful Post:
    kospoz (21st December, 2018)
  3. #32
    Dunker's Avatar
    Yorkshire
    U say live data shows 800 bar at 1000 rpm. I'd be investigating this 1st. U say it's had a SCV but was it new? Hard to diagnose without being there. Who knows if yr ECU puts a code for too high pressure. We all know it should but....
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  4. #33
    Jul 2013
    yorkshire
    Had something similar, a injector leak off test showed #3 injector leak off excessive. Pump pressure went sky high to compensate and then shut down.
  5. The Following 2 Users Say Thank You to autoden For This Useful Post:
    Dunker (21st December, 2018), kospoz (21st December, 2018)
  6. #34
    EUROPE
    Quote Originally Posted by autoden View Post
    You had smoke from exhaust?
  7. #35
    EUROPE
    Quote Originally Posted by SvenR1 View Post
    I am thinking for injectors but testing company claimed that was 100% good
  8. #36
    Jul 2013
    yorkshire
    A leak off test is 100% proof. For me its the #1 test.
  9. #37
    Meat-Head's Avatar
    Did hear of main dealer, did leak off all ok, ended send away, fawlty ones
