Is EGR stuck open?
I have this car(client bought it used with problem)
problem is that car is starting good works for 3-5 seconds and switching off like there is no more fuel
when engine is on gas pedal no working and car accelerating only with spray but then I have a lot of white smoke with bad smell like regens.
I have checked injectors ok, swap fuel regulator adapted nothing,timing ok,take off dpf housing nothing but when I started like this white cloud came out from turbo exhaust like unburnt fuel.
Any ideas?
motor is 9HR
Is EGR stuck open?
no I have checked twice I have unplugged it too but same thing
maybe a compression problem?
But if it is a compression problem i would have starting problem is this right?car is starting very easy.i am thinking about hydraulic lifters is my last hope
Does the car have a fuel pump in the tank?
No this have transfer pump at the back side of high pressure fuel pump
What about fuel quality. Does it smell of gasoline?
Louislesinge (15th December, 2018), Meat-Head (13th December, 2018)
DTC?
ECU software org or reprogram (dtc OFF)
Fuel filter checked?
Check fuel presure in rail after start motor.
You check fuel regulator on pump, but checked presure meter on rail?
khoums (11th December, 2018), Stelaras26 (13th December, 2018)
Fuel filter i think if was bad car has not been able to start immediately.i have a doubt about fuel pressure sensor but i will have some dtc about it.i can not say for program i do not know owner said that he bought it with small price but car had this problem.abra catabra
hello !
Maybe you have exhaust blocked, put the exhaust pipe after turbo down and test it.
Tom
update-->i have changed camshaft and the same thing
So you get a fuel cut out.!Car is in need of more fuel,or has overpressure,so ecu cuts out .Are you sure you have pressure in the fuel rail?
DTCs?
my guess is the pump thats failed.
