Results 1 to 15 of 15
    Dec 2016
    Default Citroen SID807evo DTC off
    Hi friends,
    I need DTC U1400 and U1401 off for the attached dump C4 picasso 1.6HDI SID807evo.
    Team dz's Avatar
    Apr 2017
    ALGERIA
    This can not be removed from the map !
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  3. The Following User Says Thank You to Team dz For This Useful Post:
    jawjan (10th December, 2018)
    Dec 2016
    Quote Originally Posted by Team dz View Post
    i read full backup by kTag, do you need other file or it can be done at all?
    morfej's Avatar
    U errors are different than P.
    U1400 Alternator LIN network : Registering of a fault on the LIN network
    U1401 Alternator LIN network : Registering of a fault on the slave node of the Alternator LIN network
  6. The Following User Says Thank You to morfej For This Useful Post:
    alclot (11th December, 2018)
    Sep 2016
    of course is possible cut this dtc.
    FILE SERVICE
  8. The Following User Says Thank You to voltechcar For This Useful Post:
    Ignasvw (12th December, 2018)
  9. #6
    morfej's Avatar
    And start-stop system will work ? ... I don't belive that.
  10. #7
    Team dz's Avatar
    Apr 2017
    ALGERIA
    The total dtc is 323 In the table damos .
    Where did you find the deletion of this error? voltechcar
    7 It is impossible to delete it
    # Algerian #
  11. The Following User Says Thank You to Team dz For This Useful Post:
    maajkii (11th December, 2018)
  12. #8
    Dec 2016
    there is not startband stop option, but it is euro5 which need controlled alternator via LIN bus
  13. #9
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    your dtc off file pass in pm
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
  14. The Following User Says Thank You to boomeer For This Useful Post:
    jawjan (12th December, 2018)
  15. #10
    Sep 2016
    Team dz please turn off asc and other automatic software, turn on winols and check dtc table, than you know how cut this dtc.
    FILE SERVICE
  16. The Following 2 Users Say Thank You to voltechcar For This Useful Post:
    boomeer (12th December, 2018), Ignasvw (12th December, 2018)
  17. #11
    Team dz's Avatar
    Apr 2017
    ALGERIA
    You're wrong, my friend. I do not use the programs you mentioned
    This is a guide you can see and learn
    The total dtc is 323 in the Damus table.
    1400 is not in the table and you are in it
    How much is the error number in the table .
    # Algerian #
  18. The Following User Says Thank You to Team dz For This Useful Post:
    Popotecnica (24th March, 2019)
  19. #12
    Sep 2016
    great, so now look again and cut this dtc
    FILE SERVICE
  20. #13
    Team dz's Avatar
    Apr 2017
    ALGERIA
    I'm still and I'll stay in the challenge with you
    You are the one who says you use programs and others
    Where is the error code 1400? I use maps with you
    Not as you like empty words
    # Algerian #
  21. The Following User Says Thank You to Team dz For This Useful Post:
  22. #14
    Sep 2016
    I not have company which teach other, turn on think and search again. My winols show this error, maybe your is broken.
  23. The Following User Says Thank You to voltechcar For This Useful Post:
    Ignasvw (13th December, 2018)
  24. #15
    Team dz's Avatar
    Apr 2017
    ALGERIA
    voltechcarnot any one can work with winols so teach your self first and speak her
    if you have any explain just share it her in dk. we help each other not just talking in air.
    i have damos and i help any one need help for free i found in my damos 323 DTC just explain to me perhapse i m wrong
    # Algerian #
