Results 1 to 5 of 5
    alexandrosts's Avatar
    Feb 2017
    there where civilization started
    Default opel corsa d z14xep need trouble code off maps p0136
    i have an opel corsa d 2007 petrol with 1.4l z14xep engine and i need to remove the trouble code p0136 of the maps ,please help
    maps have been read with kess
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    dtc off for you
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
  3. The Following User Says Thank You to boomeer For This Useful Post:
    alexandrosts (12th December, 2018)
    Feb 2017
    It worked perfect, thank you. If is not to much to ask could you tell me witch program you used to remove this dtc? Because the ones i have they don't do much, or if you suggesting any good software for this job please advice
    Sep 2016
    software have name Winols, fast check on your file and
    DTC TABLE :A4300
    DTC SWITCH : 986CA
    98718 -> change on 0 and p0136 is off.
    FILE SERVICE
  6. The Following 2 Users Say Thank You to voltechcar For This Useful Post:
    bajad (13th December, 2018), konq100 (14th December, 2018)
    Feb 2017
    ohh ok i do use ecm but i am not sure that i can do this kind of procedures with ecm at least i dont know how to use it. thank you
