Results 1 to 5 of 5
    Aug 2013
    Spain
    Default Clio UCH swap N3 to N2
    I have a Renault Clio with faulty UCH, the car have a N3 P8200272302 D V5.2, I cannot find the same, i try clone in a N2 P8200387289 B V5.5. The cars start, all work well but the remote key close but not open. I read in another threads that this can be codified with can clip. What i must modified with clip?
    panos_k's Avatar
    GR pankar
    Hi, If you have clip select remote with 1 button in parameters.
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Put ignition on, press and hold manual lock ( on the dashboard) until you hear 1 beep or double beep, do it twice and test your remote again.
    Greetings,
    hello,
    not shure you can swappe n3 on n2
    may be make a virgin and re configure it with clip
    n3 have not the same option (automatic light for example)
    read this subject post 4
    http://www.digital-kaos.co.uk/forums...N4-Virgin-file
    Aug 2013
    Spain
    I Solved with clip, really is so easy. You must go to UCH, configuration, then chose remote, this show where change configuratión UCH, dashboard or central locking, we must chose UCH. then select N2 or N3 (select the original, in my case the cars have a N3 but i clone in a N2, i must select N3). this write the new configuration. accept and exit. Sorry for my bad english.
