Results 1 to 10 of 10
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default HELP TO READ DELCO HSFI 2.1 WITH CARPROG
    i need to read an ecu delco HSFI 2.1 with carprog (to get pin)
    what cable i have to use? The color of carprog pin out cable is little "confused"...
    i need only this connection to read it in bench?
    Thank you...
    Feb 2017
    Eu
    look here...
    I would do it lke this:
    Use external 12V.
    Use A10 adapter.
    Connect external 12V to ecu and to red-wire A10. (also blue-wire A10 to 12V IGN (toggle) ON/OFF).
    External ground to Case and to black-wire A10.
    Connect A10 green-wire k-line.
    I would not use relay; just put 12v directly.
    U sure you dont want to read pin OBD?
  3. The Following User Says Thank You to fabrag For This Useful Post:
    Panathaole (11th December, 2018)
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    thank's...
    i think, i have trouble with my carprog..... i check the voltage to the a10 adapter and i have 10 v (i give 12 v to board) only in black wire (k line??????? black????)
    i think my adapter is a s***t..... with a9 adapter everything is ok....
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by fabrag View Post
    look here...
    Use external 12V.
    Use A10 adapter.
    i follow your advice and connect to ecu only k-line cable and feed the ecu with external power.... and i think i read and reset the ecu.....
    the color of the a10 adapter is different.... is not like usually programmer.... black is k-line
    this is what i get...
    originaleeprom.rar
  6. The Following User Says Thank You to Panathaole For This Useful Post:
    fabrag (12th December, 2018)
    Feb 2017
    Eu
    Strange Red & Black are always + & -....
    Did Carprog read pin?
  8. #6
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    nope in adapter a10 black is k-line.... purple is power.. red +5v...etc...
    check post #4 eeprom... read and reset pin to FFFF
  9. The Following 2 Users Say Thank You to Panathaole For This Useful Post:
    fabrag (12th December, 2018), PierreTheron (12th December, 2018)
  10. #7
    PierreTheron's Avatar
    Centurion,South Africa
    i never needed adaptor inbetween .. just direct connection to ecu with a relay i believe
    So make live less complicated i believe
  11. #8
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by PierreTheron View Post
    Direct? How??? you need cable right?
  12. #9
    Plug ecu into Vehicle and read through obd2
    Or on bench u use OBD2 connector and connect as by instructions
    I do not use A10 cable
  13. #10
    Jan 2016
    I confirm that, connection from OBD2 connecter to directly ecu does works
