Please can someone help me with mapping the EGR so its valve is permanently closed in the map and alter it so it does not give fault DTC codes
DTC 16787 egr valve
DTC 16788 egr system
Many Thanks in Advance
DTC 16787 egr valve
try and report
pass in PM
Don't forget hit thank button if i helped.
Jigsawed (11th December, 2018)
your dtc off file
REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
