Originally Posted by
pugbug
Hi, i wonder if anyone could help me with this problem.
I have an astra h z14xep that will not idle stable, i have thus far changed the throttle body, coilpack, spark plugs, replaced the ecu for a known working one, checked the wiring all over, checked for vac leaks.
I've now ran out of ideas, the eml does not come on but if any throttle input does not stabilise.
I have both tech2 and opcom, the only value that i can see that sticks out is throttle position pwm, that fluctuates a lot, and calculated throttle position changes from 2-4-6% when there is no throttle input, but it clearly says idle on tech2.
I have attached some photos, if anyone can help with id really appreciate, thx
